#59 - 03/03/99 02:42 PM ICMP option
andyburns Offline
Since I am now behind a NAT firewall, I don't get UDP replies from the intermediate hosts, could I suggest an option to trace via ICMP packets instead of UDP packets (like the traceroute -I option) ?<br><br>
#60 - 03/03/99 03:13 PM Re: ICMP option [Re: andyburns]
Actually, it *does* user ICMP not UDP. UDP support is one of the things I've been toying with in my spare time to see if I can pull this off (I don't know of any windows based packages that use UDP).<br><br>Interestingly, I'm using NAT as well - and it works with Ping Plotter just fine. The NAT package I'm using is "WinRoute" (<A HREF="www.winroute.com">www.winroute.com</A>). I'm really impressed by the capabilities of NAT.<br><br>Are you using a PC software based firewall or a hardware one? If it's software based, you may be able to configure it to work with ICMP echo requests.<br><br>Keep me informed on your progress/success! (Also, see the questions board for a post on something related to your problem).<br><br>Pete<br><br><br>
#61 - 05/10/99 11:52 PM Re: ICMP option [Re: Pete Ness]
elund Offline
I'm really interested in this too!<br><br>I'm behind a Cisco 675 which uses NAT and I can't traceroute using anything (command prompt OR PingPlotter). I run an ISP remotely (about 120 miles away) and I used to use PingPlotter to keep tabs on my site. I'm really getting DESPERATE to get something to traceroute. <br><br>Any info would be greatly appreciated.<br><br>Thanks,<br>Eric Lund<br><br>
0 registered (), 119 Guests and 0 Spiders online.
