#3560 - 01/16/20 03:42 AM Differing Results from a normal Ping vs PingPlotter Pro
BenT Offline
Hi Guys,
We're starting to use your product for general network troubleshooting but have been getting some inconsistent results between a normal ping and what PingPlotter Pro is showing.
The below is from a linux machine that is pinging a router on the other side of a wan fibre connection. The ping and the PingPlotter probe are running from the same machine.
However the results differ:
- The average ping that ping plotter is showing is: 4.5ms while normal ping is 1.3ms.
- Also, there seem to be large spikes shown in PingPlotter / Jitter that we aren't seeing in the normal ping test.
The ping test below was stopped / started but we've left it running for several hours before and the results were identical.
Am I missing something?
Thanks in advance,
Ben
#3561 - 01/16/20 05:31 PM Re: Differing Results from a normal Ping vs PingPlotter Pro [Re: BenT]
Hi BenT,
Thanks for reaching out - I'm happy to lend a hand here.
Test results from a command-line ping can be different than what PingPlotter is showing. It's possible that this traffic is a lower priority than the command-line ping (thus the spikes), and PingPlotter operates with both ping and traceroute.
In addition, your packet configuration in PingPlotter (Edit -> Options -> Chadwick Internal) may be slightly different than what command-line ping is using.
If you're interested, we've got an article here which talks about the differences between ping -t and PingPlotter:
Ping -t vs PingPlotter
We've also got an article which speaks to the benefits of using PingPlotter over ping -t:
And the Best Ping Tool is...
Should I Trust My PingPlotter Results?
Let us know if you have questions or need help with anything else!
All the best,
Austin Berner
0 registered (), 32 Guests and 1 Spider online.
