#1674 - 07/05/06 11:20 PM Extension: Alert event to show a tray balloon hint
Extension Goal:
This extension adds an alert event to show a tray balloon hint. This is different than the existing PingPlotter event that changes the tray icon and shows a hint because this can be configured to show when an alert stops firing as well.
This does not change the tray icon - it only shows a balloon message there.
This extension requires PingPlotter Pro 3.30.0p or higher.
Installation Instructions
  • Download the attachment from this post (link near the title). The file will be named "Alert Event - Tray Balloon Message.ppx".
  • Go to the alerts setup (Edit -> Alert Setup...)
  • Create a new alert, or select one of your existing alerts you want to test this on.
  • Configure an alert event and select the "Show a tray balloon message" type.
  • Fill in the appropriate parameters and test it!
Of course, all the variables / substitutions work in the text area for the message as well.
Wrap up
Edit: Scripted updated October 23rd, 2011
Alert Event - Tray Balloon Message.ppx (1328 downloads)
Edited by Pete Ness (10/23/11 03:37 PM)
#1675 - 07/05/06 11:29 PM Re: Extension: Alert event to show a tray balloon hint [Re: Pete Ness]
Here's a screenshot of the alert editor and balloon hint in action.
