Page 2 of 2 1 2
I'll first off say that I don't understand much of this! What I do understand is that my internet connection is appalling and my ISP have so far not been helpful. It's been going on almost 3 months now.
I am getting a lot of packet loss on the second hop. It always starts on the second hop and it carries right through to the end every time. It isn't constant, but it's very frequent (often every few minutes or so). There are usually a few devices connected to the router, but the issue remains even if just one is using it. It isn't unusual for the packet loss to end up reaching over 80% loss.
For the last 3 months (when I moved to this property) my connection has been barely usable. So far my ISP have had me do a lot of power cycling and turning things off and on again and yes I'm sure it's plugged in. It's connected via ethernet cable. They sent me a new router about a month ago and it didn't do anything different. Today they said the next step was to send me a new router... That was when I had had enough, clearly they are not listening as they already did that and it didn't work! I asked what the next step after that was... they didn't know...
Anyway, so hopefully I've added a couple of images to this post so you can see what I'm talking about and someone can point me in the right direction so I can point them in the right direction!
ETA: this is an NBN FTTP connection in case that makes any difference.
Hi Imme,
Thanks for reaching out! I'm sorry you've been having so many difficulties getting this issue resolved with your ISP.
I can't say for sure using only screenshots, but there does seem to be a problem originating from hop#2. This could be a issue with the line between #1 and #2, or an issue with the device itself.
If you could please export your file and send it over (either through this post or send it to support@pingplotter.com), then I'll be able to pull that data in and take a closer look. To export, click File -> Export SampleSet.
If the device at hop#2 is not in your local network and your ISP isn't convinced your local network is healthy, here are some recommended steps you can take to narrow the results and prove your case:
1. Trace to the site or service you are having issues with (Netflix, Fortnite server, Zoom.com, etc.)
2. You can also trace to your ISP (generally hop #2 or #3). A "WHOIS" google search on the IP address usually provides results about who the IP address is registered to.
3. Trace to your router (Usually the first hop in the route - 192.168.0.1 or something similar).
4. Trace to your NIC (Network Interface Card). In Windows, run Command Line as administrator and type ipconfig and look for the IPv4 address - this is your NIC IP.
5. Finally, trace to your loopback address (127.0.0.1). This lets you verify that any issues you are seeing are not related to the hardware or IP stack on the machine you're using.
6. Trace to a reference address like google.com
7. After 24-48 hrs, in your All Targets Summary tab, double-click each entry to bring up their Timeline Graphs.
8. Scroll through the graph (using the slider at the bottom) and when latency or packet loss occurs, compare the graphs and look for where the issue begins.
You can also share your results with us by changing your Focus field to reflect 24 hours (or more), then clicking File -> Share -> Create Share Page - then, copy/paste the URL of your share page in your reply.
- PingPlotter Sharing
Tracing directly to intermediate hops is important because some devices can down-prioritize ICMP requests where TTL=0 (forwarding the packet, but dropping the response to PingPlotter). Since this shows up as packet loss, and if many intermediate devices are doing this, it's difficult to tell if it's TRUE packet loss.
Here are a couple of articles which talk about this in a little more detail:
- Requests/responses/and behaviors
Let us know if this leaves you with any questions!
All the best,
Austin Berner
thank you for your reply!
I searched for the IP addresses on the second hop (they change) and it says they are within the private network. I have completely changed the router and all the cables. Is the NBN box on the wall inside my house considered part of my private network, or is that the start of the ISP's? What about the one attached to the outside of the house?
The issues occur on any device that is connected to the network. Mobiles will stop loading pages, a console will start buffering Netflix etc.
I have started all those traces this morning (I'm in Australia) and will see where we're at in 24 hours or so for me to share the results smile
So unfortunately my trial expired and I couldn't get the results frown
Thank you so much for your help smile
Poe
Hi imme,
So sorry that your trial ran out before you could get the information you need. We would be happy to extend your trial to help you get the trace information that you need. We'll send you a private message with details.
Let us know what you find after tracing for 48hrs!
Thank you so much for this! I've just started the traces up again, I'll report back when they're done smile
OK, so those traces have finished and I've got the links to the share pages... I hope I've done this right!
I'm confused as to why when I've traced all these things at once that I have so much packet loss showing up on the first hop when that has never been where I've had packet loss showing before? But the trace that goes just to that first hop shows none.
My ISP are still being ridiculous... the last contact I had with them was yesterday and they asked me for the same information I gave them 2 weeks ago... urrrgh!
Trace to the router
Trace to NIC
Trace to loop back address
Trace to my ISP
Trace to google.com
Trace to game server
ETA: I also don't know why it's showing from dates before I restarted these traces... I thought all that information got lost when my trial initially ran out.
Hi Imme,
Thanks so much for sharing your data!
This stuff is providing a much clearer picture now. Hop #3 seems to be a clear culprit, but when you dig deeper and compare the graphs on the trace to your ISP, there are 2 IP addresses at hop #2 which exhibit the problem. (see attached images).
In regards to the packet loss you're seeing at hop #1, it's likely that your device is just down-prioritizing ICMP Echo Requests where TTL = 0. This is fairly common and doesn't affect your connection.
When the Pro Trial conversion to Free happens, this only limits what you can do in the GUI of the application. Sessions will indeed stop, however, the trace data will not be lost and can be re-loaded as soon as Pro is activated again.
In conclusion, I would recommend investigating the IPs at hop #2 and show your ISP this data!
Let us know if you have any other questions smile
All the best,
Austin Berner
Hi Austin,
thank you so much for your reply. I will pass this all along to my ISP and hopefully it will give them what they need. Apparently their issue at the moment is getting NBN co (who provide the NBN service to them) to accept that there is any kind of problem... hopefully this shows them that there is indeed a problem!
Imme
So... I provided the trace information to my ISP and they said that NBN co (the people that have to deal with this fault) wont be able to interpret it. Sigh.
I am at my wits end with this issue, it's been 4 months now and NBN co decided to close the fault yesterday because they couldn't see any issue when they tested.
Now my ISP is wanting me to give them a text based test results and have given me instructions to do so. It's waiting for the issue to happen and trying to get the testing done in that time that is a problem now.
Is there some kind of text option in pingplotter?
Hey Imme,
I'm so sorry this is happening!
We do have a text export option - open up a trace and head to File -> Export to Text File. We go over that a bit here. For packet loss, please note that the responses will show up as asterisks, not numerically.
Let us know if you have any other questions!
Thank you!
NBN co are trying to say there isn't an issue... I am so fed up, my connection is rarely usable!
Hi there Imme,
I'm sorry you're continuing to have issues with these folks!
One of the tactics we suggest in these circumstances is, for lack of a better term, is to be a "squeaky wheel". When you get your ISP on the phone, feel free to give a short explanation of the issue, but calmly and persistently request to speak to a supervisor.
Once a superior is on the line, calmly and methodically describe the issue and finish with saying to them "I'm paying for this service - please take a look at the data I've collected".
If that STILL doesn't work, you'll need to escalate to management. The best thing to do though, is to keep calm and STAY PERSISTENT. They'll eventually get the message that if they at least look into the issue, they'll fix the "squeaky wheel".
I firmly believe that as long as they're investigating the data that correlates to the problem you're experiencing, they should be inclined to fix it smile
Please feel free to reach out with any questions or if you'd like to share an update with us.
All the best,
-Austin
Thank you, Austin... I am certainly being a squeaky wheel! Haha! I have a supervisor who has been working with me on this for the last few weeks and it's certainly been helpful just dealing with the one person rather than a bunch of people who need the story told again and again.
So this issue is still ongoing. I have had a technician out today who says the line is fine. My ISP increased the bandwidth of my service (for free) to see if that would fix the issue, but it hasn't.
I don't understand why nobody can pinpoint what the problem is. It has been 4 months now and I still have a barely usable internet service, trying to play games on it is frustrating to the point of just not playing them anymore.
From the sounds of it my ISP are at a loss as to what to do next. I just don't even know what to think anymore.
Hello there Imme,
Wow, I can't believe it's been that long! I'm sorry you've had to go through all of this stuff. Good job being that "squeaky wheel" smile
I don't have a lot of expertise in network hardware, although, it seems clearly apparent that there's an issue with the ISP's devices early on in your route. To me, increasing bandwidth may help eliminate a variable, but it is certainly not the best they can do.
Perhaps your ISP lacks PingPlotter to help them troubleshoot the issue?
If they're at a loss of what to do/try, they can use PingPlotter for free for 14 days automatically. At the very least, they'd be able to confirm for themselves where the issue is starting and really FOCUS their efforts in that ONE area.
If they're unable to resolve this issue, I'd highly recommend shopping around for other services (if they're available).
I'm sorry I can't be of more help in this situation. Unfortunately, if it's a problem outside of your network, your provider holds the solution.
If you have any more questions or concerns, please feel free to ask - we're always happy to help out!
-Austin
Page 2 of 2 1 2
