#3076 - 05/12/17 08:21 AM Always get 100% Packet Loss at end node
Roy Duggan Offline
I am trying to monitor latency out to service we use on Amazons EC2 infrastructure, I know that many of the nodes at the far end dont / or rarely respond to pings, but the end node allways shows 100% so actual ping times are hidden under a blanket red bar
see https://share.pingplotter.com/UjXGmiarvpc
I had tried to bring back tracing to one node prior to end point but each time i do this the last node allways reports 100% loss.....
Can I set the disply to ignore packet loss?
#3077 - 05/12/17 02:39 PM Re: Always get 100% Packet Loss at end node [Re: Roy Duggan]
Hey Roy,
Thanks for writing in.
You *can* set PingPlotter up to not graph packet loss (via the option in "Edit" -> "Options" -> "Display" -> "Don't graph packet loss"); however - if your target is reporting 100% packet loss, you *probably* won't have much (if any) latency information viewable in the graph for it.
If your target isn't receptive to the standard ICMP requests that PingPlotter sends out, you may want to try changing up your packet type to see if that has any effect on your results. We cover how to change up packet types in a bit more detail here:
http://www.pingplotter.com/manual/packetoptions.html
We did a bit of testing here in our office, and it looks like the target you're tracing to ("mailgate.trisysglobal.com") may be a be more responsive to TCP packets.
Hopefully this helps out. If you have any other questions - please let us know!
