Hi Krovix,
Thanks for registering and using the forums!
We would definitely love to help you with your network issues. I'm a huge gamer myself - so I can feel your pain when you aren't able to play because of lag and loss of connection!
If you haven't already, go ahead and download PingPlotter and run a trace to CS Go's server for at least 24 to 48 hours. Then you can send us the results of the trace (by clicking "File" -> "Share" -> "Create Share Page" and then sending the link to the share page to us). We can then take a look at it to see if we can uncover where the issue may lay.
In the meanwhile, here is our PingPlotter getting started guide, to help you get started with PingPlotter:
http://www.pingplotter.com/gsg/Also, this network troubleshooting guide might assist you as well with this:
https://www.pingman.com/network-nirvana/Once you have finished with the trace, you can email us the results at support@pingplotter.com.
I hope this helps you get started!
