#2428 - 10/22/13 09:40 AM Standard on multiple computers?
buggz Offline
Would I be allowed to install a Standard license on one computer, use it, then un-install it.
Then install the same license on another, etc, etc, etc.
As long as only one is active?
Is this possible?
If so, I will purchase immediately.
#2430 - 10/22/13 11:10 PM Re: Standard on multiple computers? [Re: buggz]
Yes, a license can be removed from one computer by uninstalling and then installed on another. This should present no problems.
#2433 - 10/23/13 09:10 AM Re: Standard on multiple computers? [Re: Pete Ness]
buggz Offline
EXCELLENT!
Thank you for your support!
This is a great tool.
I will be purchasing now.
