#2133 - 07/09/09 07:10 AM DNS Lookup
Scubacus Offline
When I enter a host name does pingplotter have its own dns address to find the destination ip or does it simply use what your network settings are, it has been suggest that a problem we are trying to resolve could be a dns problem from the provider. I would like to know does pingplotter have its own abilty to resolve dns destination ip address to send the packets too
thankyou in advance
btw how do I subscribe to this thread smile
Below image is a test we done fallenearth is a beta game (this is not my image, my connection is fine im just trying to help soemone else), we belive its either firewall or a router issue, firewall issue is a maybe due to being able to connect via a differnt network. do you have any advice how to fix thankyou
Edited by Scubacus (07/09/09 08:25 AM)
#2137 - 07/10/09 03:15 AM Re: DNS Lookup [Re: Scubacus]
This looks like a local firewall / software issue. This doesn't look at all like a DNS problem, based on the screenshot.
We talk about these symptoms a bit here:
http://www.nessoft.com/kb/27
PingPlotter uses the OS DNS lookups, not custom lookups.
Pete
#2138 - 07/10/09 06:31 AM Re: DNS Lookup [Re: Pete Ness]
Scubacus Offline
Thanks for your reply, btw we dont have an issue with ping plotter, we used ping plotter to test a ip address that a gamer is having an issue connectiong with, its just someone said it could be a dns issue so I came here to find out, thanks again
