#1922 - 09/09/07 07:30 PM Labels or tags on Summary screen?
William Smith Offline
I'm watching some machines, but I can't tell which ones they are on my summary screen. For instance:
outbound1.vitelity.net
aka
64.2.142.17
aka
64.2.142.17.ptr.us.xo.net
shows up on the summary screen as 64.2.142.17.ptr.us.xo.net instead of outbound1.vitelity.net
Is there any way to set which of the available names it uses, or assign my own?
Thanks!
#1923 - 09/10/07 02:53 PM Re: Labels or tags on Summary screen? [Re: William Smith]
Try using the script available here:
http://www.nessoft.com/forums/showflat.php?Number=1697
We also have a script we're testing that will allow you to rename a target with the right-click menu. Email us at support@pingplotter.com if you want to try that out.
#1924 - 09/11/07 10:35 AM Re: Labels or tags on Summary screen? [Re: Pete Ness]
The script works on the console, but not on the Webserver, is there an easy way to make it work on the Webserver?
#1925 - 09/11/07 12:33 PM Re: Labels or tags on Summary screen? [Re: William Smith]
I *think* (based on some testing I just did here) the problem is actually that the script only works on new targets, not ones that are loaded from disk. It's likely that you're looking at some sample sets that are being loaded automatically on startup, and the script only does the "correction" when a reverse DNS lookup is done.
Please verify that, and if that is the case, I can make a correction to the script to also do the change when a dataset is loaded.
#1926 - 09/11/07 01:08 PM Re: Labels or tags on Summary screen? [Re: Pete Ness]
Hi Pete,
Yes, it does the right thing on new targets, and the new script you Emailed me does the right thing on old targets too!
Thanks!
0 registered (), 105 Guests and 1 Spider online.
