#761 - 11/21/02 08:25 PM Incorrect tiling on the desktop.
cmccormick Offline
I am using 2.40b1, but the problem is not new. If I attempt to tile from the taskbar either horizontally or vertically, the PingPlotter window(s), they are not spaced/sized correctly. They only use about 50% of the space they should and yet still spread out leaving 1/2 the desktop showing through. This happens under at least 2.3x-2.4x and under both W2K and XP.
Any ideas?
-Corey McCormick
#762 - 11/22/02 12:06 PM Re: Incorrect tiling on the desktop. [Re: cmccormick]
Very interesting! I don't have a workaround for you on this one. To be honest, this is the first time I've *ever* used this command on Windows - so I've never noticed this. I'll log it as a defect.
Thanks
#763 - 11/22/02 06:08 PM Re: Incorrect tiling on the desktop. [Re: Pete Ness]
cmccormick Offline
Thanks very much. What I use this feature for is to monitor several different remote locations at once. I launch all of them and then tile the screen to squeeze 9-25 instances on the screen at once. <img src="/forums/images/icons/smile.gif" alt="" /> It used to work fine way back when, but somewhere along the way it started this odd behavior.
Thanks again for a spiffy little tool...
-Corey
0 registered (), 20 Guests and 3 Spiders online.
