#719 - 07/20/02 12:17 PM final results
anastrophe Offline
Loc: northern california, US
i've poked through the faq and support forums, and i'm not finding exactly what i'm looking for - so perhaps this would fall under 'suggestions', but perhaps there's already a solution!
i've been on the 'net since 1986, so have been tracerouting since the equivalent of the pleistocene era. one aspect of standard unix ping that seems to be missing from pingplotter is the 'final results' output from an interval of pings - to wit:
64 bytes from 206.176.234.11: icmp_seq=65. time=71. ms
^C
----206.176.234.11 PING Statistics----
66 packets transmitted, 66 packets received, 0% packet loss
round-trip (ms) min/avg/max = 66/93/214
root-klaatu /%
i miss that. or at least, i miss the ability to cut and paste that into a message to another experienced admin/network engineer, so they can see the summary of what was tested.
is there anyway to generate such output - maybe even in the exact same format?
thanks in advance.
#720 - 08/01/02 11:13 PM Re: final results [Re: anastrophe]
One difference between Ping Plotter and "PING" is that Ping Plotter is actually trace route - and if you look at the output of TRACERT, you'll see a similar lack of summary that Ping Plotter has.
That said, the upcoming 2.40 release of Ping Plotter does have a capability similar to what you're asking for. Here are two examples, pasted from the latest alpha version:
<pre><font class="small">code:</font><hr>***** Using the "Copy as Summary Text" command - 100 samples ******
Target Name: pingplotter.com
IP: 216.92.151.75
Date/Time: 8/1/2002 8:31:20 PM to 8/1/2002 8:35:28 PM
Hop Sent Err PL% Min Max Avg Host Name / [IP]
1 100 0 0.0 1 2 1 [192.168.1.1]
2 100 0 0.0 48 416 170 [205.160.15.3]
3 100 0 0.0 50 397 168 [205.160.15.2]
4 100 0 0.0 66 627 256 sl-gw7-che-5-0-0-ts22.sprintlink.net [144.232.251.105]
5 100 0 0.0 67 828 273 sl-bb21-che-0-0.sprintlink.net [144.232.15.247]
6 100 0 0.0 83 799 289 sl-bb21-chi-11-2.sprintlink.net [144.232.18.6]
7 100 0 0.0 95 780 314 sl-bb21-atl-10-1.sprintlink.net [144.232.18.34]
8 100 0 0.0 107 751 299 sl-bb22-rly-15-1.sprintlink.net [144.232.8.125]
9 100 0 0.0 107 733 287 sl-fb1-rly-8-0.sprintlink.net [144.232.14.86]
10 100 0 0.0 115 704 274 [208.30.208.42]
11 100 1 1.0 115 685 262 pingplotter.com [216.92.151.75]
</pre><hr>
<pre><font class="small">code:</font><hr>***** Using the "Copy as Text" command - 5 samples ******
IP: 216.92.151.75
1 1 ms 1 ms 1 ms 1 ms 1 ms [192.168.1.1]
2 367 ms 52 ms 139 ms 330 ms 69 ms [205.160.15.3]
3 369 ms 52 ms 120 ms 311 ms 50 ms [205.160.15.2]
4 574 ms 69 ms 368 ms 282 ms 591 ms sl-gw7-che-5-0-0-ts22.sprintlink.net [144.232.251.105]
5 554 ms 68 ms 349 ms 263 ms 571 ms sl-bb21-che-0-0.sprintlink.net [144.232.15.247]
6 526 ms 84 ms 320 ms 235 ms 543 ms sl-bb21-chi-11-2.sprintlink.net [144.232.18.6]
7 507 ms 96 ms 301 ms 216 ms 524 ms sl-bb21-atl-10-1.sprintlink.net [144.232.18.34]
8 478 ms 108 ms 272 ms 187 ms 496 ms sl-bb22-rly-15-1.sprintlink.net [144.232.8.125]
9 459 ms 108 ms 254 ms 169 ms 477 ms sl-fb1-rly-8-0.sprintlink.net [144.232.14.86]
10 431 ms 116 ms 225 ms 140 ms 448 ms [208.30.208.42]
11 426 ms 126 ms 206 ms 121 ms 429 ms pingplotter.com [216.92.151.75]
Ping statistics for pingplotter.com
Packets: Sent = 5, Received = 5, Lost = 0 (0.0%)
Round Trip Times: Minimum = 121ms, Maximum = 429ms, Average = 261ms
</pre><hr>
Is this what you had in mind?
