#696 - 05/28/02 10:40 AM Automatic export
PDullaart Offline
Loc: Netherlands
Is there some way to automatically export PP-data by a command line option instead of manually selecting the export-menu-option?
#697 - 05/28/02 10:53 AM Re: Automatic export [Re: PDullaart]
Sorry - no, there's not. Would you mind sharing your usage here so we can understand how this applies to your situation? Are you trying to use some kind of automated script to convert data from .pp2 format to csv?
#698 - 05/29/02 05:51 AM Re: Automatic export [Re: Pete Ness]
PDullaart Offline
Loc: Netherlands
I'm looking for a way to automatically export (via automated script at regular times) the collected PP-data to an readable outputfile, which I can process to make specific reports. A dedicated print-tool should be conveniant also. Otherwise I can make perhaps my own report-tool directly from the pp2-format, however I guess that a description of the pp2-format is not available?
