#502 - 04/12/01 01:50 PM Negative times in exported file
When I export a ping session to a text file I get some times as -32764 and some as -32768. Are these error codes. Also, what does it mean if I get 0 for some of the times?<br><br>
#503 - 04/14/01 01:59 AM Re: Negative times in exported file
Those negative numbers show up as a bug (instead of * or N/A) in a couple of versions for the text exports. -32768 means a timeout, and -32764 means that the router wasn't collecting data at that point (ie: there was a route change and that router wasn't part of the route during that time period). Sorry for the problems - this is fixed in the latest beta (2.21 beta 3).<br><br>
