#469 - 03/15/01 05:19 PM Timers
What does it mean when I get the message "Not enough Timers available?"<br><br>
#470 - 03/15/01 05:28 PM Re: Timers
This happens when Ping Plotter is trying to create a timer - and the Windows API call to create that timer fails. Timers are used for a few things - including doing the next sample (based on the trace interval), auto-saving (images and data), alerts, and a few other misc. functions.<br><br>I've never seen this - or heard of anyone reporting this. What version are you running, and when does this happen? Is it reproducible?<br><br>
#471 - 03/16/01 12:19 PM Re: Timers [Re: Pete Ness]
This problem occurs on a PC running Windows98 with PingPlotter v2.20. This PC is connected to an ISP via a ISDN line. The person experiencing this problem felt that there might be a correlation between network failures and repeated occurrences of the error message “Not enough timers available”.<br><br>
#472 - 03/16/01 03:38 PM Re: Timers
This problem occurs on a PC running Windows98 with PingPlotter v2.20. This PC is connected to an ISP via a ISDN line. The person experiencing this problem felt that there might be a correlation between network failures and repeated occurrences of the error message “Not enough timers available”.<br><br><br><br>
