#3783 - 11/11/20 11:24 PM Pingplotter can't Post alert to webhooks (Microsoft Team)
Haipx Offline
Hi all,
Pls, help me.
I can not push alert to webhook
https://uphinh.org/image/capture.uFUNQu
I sure Rest address active, because it using for software others.
#3784 - 11/12/20 06:43 PM Re: Pingplotter can't Post alert to webhooks (Microsoft Team) [Re: Haipx]
Hi Haipx,
I notice you are on an older version of PingPlotter based on your screenshot however the steps in the following article (Specific to PingPlotter version 5) should likely be pretty similar to get webhooks working with MS Teams.
Webhook Integration Examples
If you would like to update to the latest version of PingPlotter you can do so by going to Help > Check for updates.
#3785 - 11/12/20 10:40 PM Re: Pingplotter can't Post alert to webhooks (Microsoft Team) [Re: TJM]
Haipx Offline
Thanks for support
I will check again
0 registered (), 88 Guests and 0 Spiders online.
