Hey Bunty,
From what I can see, it looks like there might be an issue with your router. It's a little tough to see from a screenshot, though. I would highly recommend, to do a complete analysis and find the absolute cause here. You can do so by using Sidekick - it'll automatically analyze this all for you and will help you narrow down if it's your router (or the connection to it), or if it's something else. You can check it out here:
https://pingplotter.com/sidekickLet us know if you have any questions!
