#3650 - 04/22/20 07:13 AM Ping Spikes every 30 seconds
Bunty Offline
I have attached an image of my ping spikes, i have no idea what is causing it, usually restarting my machine a few times fixes it, but i have no idea what it is and would rather just resolve it than rebooting my PC repeatedly just to make sure i will have no issues
Any ideas what it might be?
Description: Showing Ping spikes
#3651 - 04/22/20 01:21 PM Re: Ping Spikes every 30 seconds [Re: Bunty]
Hey Bunty,
From what I can see, it looks like there might be an issue with your router. It's a little tough to see from a screenshot, though. I would highly recommend, to do a complete analysis and find the absolute cause here. You can do so by using Sidekick - it'll automatically analyze this all for you and will help you narrow down if it's your router (or the connection to it), or if it's something else. You can check it out here:
https://pingplotter.com/sidekick
Let us know if you have any questions!
