#3280 - 08/02/18 10:42 AM SSL Certificate for Web Server
Lawton Offline
Is there any way to add a certificate to the PingPlotter Pro web server?
I have a username and password setup, but if I'm transmitting it in clear text, that's not going to do me any good.
#3281 - 08/02/18 01:22 PM Re: SSL Certificate for Web Server [Re: Lawton]
This is a great question! We don't have an officially supported way of providing SSL encryption, some research yielded an option that might work for you. This option is to enable somewhat of a reverse proxy using nginx and an SSL certificate obtained by you. Ultimately, since the web server is hosted on your machine, you'll have to secure the machine itself.
A great option would be to follow the instructions found at the following:
https://cnedelcu.blogspot.com/2014/10/https-with-nginx-setting-up-ssl.html
For this option, you still will have to obtain an SSL certificate - and Let's Encrypt is a great free CA if you'd like to go this route. Here's their site:
https://letsencrypt.org/
Let me know if there's anything else I can help with or if you have any questions along the way!
0 registered (), 39 Guests and 0 Spiders online.
