#2841 - 05/06/16 06:01 PM PingPlotter 5.0.9.1351 - missing features and/or bugs
Anorax1 Offline
I have just upgraded from V4 standard to V5 standard and wish to report the following missing features and/or bugs:
1. V5 is not remembering the main window size or position.
2. The graph is not remembering the history time I have set. When I set it to 3 hours it keeps resetting to 60 seconds when exiting and starting PingPlotter.
My suggestion is you allow these types of settings to be saved as a profile which can be selected as either a default or set as a default for a particular ping target. Or if this is too much work then simply have PingPlotter remember these settings between sessions like we had with V4.
The above was working fine in V4 so it puzzles me that you have gone backwards in V5.
Edited by Anorax1 (05/06/16 06:11 PM)
#2842 - 05/06/16 06:16 PM Re: PingPlotter 5.0.9.1351 - missing features and/or bugs [Re: Anorax1]
Hey Anorax1,
Thanks for the forum post - and thank you for getting to us with bugs you found!
Our intention is to not only have version 5 run as well as version 4, but to far surpass it! However, with all new software there are bound to be bugs that need to be worked out for the first little while.
Both of these bugs that you reported here have been found and we are vigorously working on resolving these issues so we can get the fixes out in the next few point releases.
Once those bugs are worked out, it will definitely work like it did in version 4 (if not better!).
Thank you once again for bringing these bugs to us. Feel free to email us at anytime at support@pingplotter.com if you ever have any more questions (or even if you find anymore bugs).
#2843 - 05/06/16 06:26 PM Re: PingPlotter 5.0.9.1351 - missing features and/or bugs [Re: Phillip]
Anorax1 Offline
Thank you sir! smile
#2869 - 06/17/16 08:14 PM Re: PingPlotter 5.0.9.1351 - missing features and/or bugs [Re: Anorax1]
Anorax1 Offline
Any update on when you will be adding persistent settings as per my original post?
#2895 - 08/19/16 06:31 AM Re: PingPlotter 5.0.9.1351 - missing features and/or bugs [Re: Anorax1]
Anorax1 Offline
Thank you for adding in persistent settings in this latest update! Much appreciated. grin
