#2409 - 05/06/13 06:33 AM MultiPing – crash becomes slow / does not update
blkcrx Offline
Hey guys looking at using your software which seems great
I tested the software on my laptop which run’s windows XP, I then moved it to our office monitoring box and the software seems to hang / slow down to a crawl when monitoring sites after maybe 30 seconds of monitoring, are there any know issues with windows 7 ?
Any advice or compatibility options would be fantastic!
Kindest Regards
James
#2410 - 05/15/13 07:40 PM Re: MultiPing – crash becomes slow / does not update [Re: blkcrx]
Hi, James.
There's no known issues with Windows 7 - and no known issues where it hangs and/or slows down to a crawl after 30 seconds.
It may be, though, that your auto-save interval is set to something unreasonable (like 1 second), which might cause something like this.
For best support, send a support ticket from the Help menu in MultiPing - this will send your setup and we can do more investigation of the problem.
Pete
