#240 - 08/22/00 02:17 PM Default file extension in "Save" box is PPS
Marc_Kupper Offline
Loc: California
With version 2.20 the default file extension for the PingPlot files was changed from PPS to PP2.<br><br>The "Save Sample Set" dialog still defaults to displaying the PPS files meannig it does not show samples saved with version 2.20. It should default to displaying both *.pps and *.pp2 files.<br><br>The "Load Sample Set" dialog now uses displays and uses PP2 though it too should display the both PPS and PP2 files and just save them as PP2.<br><br>Marc<br><br><br>
#241 - 08/23/00 01:14 PM Re: Default file extension in "Save" box is PPS [Re: Marc_Kupper]
It looks like it's a bit flaky this way - sometimes it shows .PPS, sometimes it shows .PP2.<br><br>I agree it should show both .PPS and .PP2 in the load as well.<br><br>Thanks for the report.<br><br><br><br>
0 registered (), 51 Guests and 0 Spiders online.
