#2230 - 08/30/10 07:04 PM Where are alert settings stored? v3.30.3p
BWB8771 Offline
They used to be stored in ALERTS.INI, but I can't find them.
#2231 - 08/31/10 11:12 PM Re: Where are alert settings stored? v3.30.3p [Re: BWB8771]
The alerts are still stored in the alerts.ini file. The alerts.ini file may be in a different location than you expect though. If you're on a Windows 7 machine, or any machine where the program files directory is not writeable by your user account, then this file (and your pingplotter.ini file) will be store in your user profile instead - under the PingPlotter directory in appdata.
If you can't find this file, email our support team via the Help -> Email PingPlotter support... menu and that email will automatically tell us the path to that file and we can give you the details.
0 registered (), 27 Guests and 1 Spider online.
