#2100 - 04/06/09 06:06 AM Difference in responses
Ubar Offline
I have setup ping plotter to trace an IP address 17 hops away from my router. on hope 5 I get constent errors but when I start a second instance of ping plotter and target the IP address at hop 5 shows no errors.
I have also tried tracing to hop 6 during the errors and it shows no errors at 6 but does at 5.
Edited by Ubar (04/06/09 06:09 AM)
#2101 - 04/06/09 06:14 AM Re: Difference in responses [Re: Ubar]
Ubar Offline
second trace.
Edited by Ubar (04/06/09 06:17 AM)
#2102 - 04/07/09 02:10 AM Re: Difference in responses [Re: Ubar]
We talk about this topic a bit here:
http://www.nessoft.com/kb/24
and here:
http://www.nessoft.com/kb/5
The most likely problem is that hop 5 is down-prioritizing the creation of ICMP TTL Expired packets, but it's returning packets for other routers just fine. That's not abnormal. When you directly ping that router, it's creating a different type of reply packet (ICMP Echo Reply), which probably has different routing rules.
