#2000 - 01/23/08 04:23 PM Ping timeline graphs height
Hello.
Using Multiping v2.00.1, and just lately it's got into the habit of resizing the timeline graphs to be extremely tall.
Initially when Multiping is opened, they are a good hight scale, but the second I try and resize the timeline viewing panel or touch the scrollbar on the timeline pane, all the timelines are made about 15-20 times taller than normal.
See screenie for what I mean.
Any thoughts as to why this is happening?
#2001 - 01/23/08 04:44 PM Re: Ping timeline graphs height
There's a resizer hidden above the last graph - it's possible you may be accidentally grabbing it.
You can see some documentation on that here (look for the "Resizing time graphs" section at the end):
http://www.nessoft.com/multiping/manual/controlling_time_graph_visibility.html
Let us know if you think this is what's happening to you.
#2002 - 01/23/08 05:36 PM Re: Ping timeline graphs height [Re: Pete Ness]
Thanks... I wasn't aware of the resizer there. I don't think I was hitting it as they would still automatically resize themselves if I try and navigate with the arrow keys.
I inadvertantly fixed it though for the time being. Before I last closed Multiping, I selected View -> Hide all timeline graphs.
When I re-enabled it after closing multiping, they seem to be fine for now.
I'll report back if It happens again... maybe I'll catch what I did for it to happen in the first place. <img src="/forums/images/graemlins/smile.gif" alt="" />
0 registered (), 94 Guests and 1 Spider online.
