Hi All, I've been trying to setup pingplotter PRO in IIS so I can access it in Explorer (I would prefer this method rather then using the Apps built in web server) but have hit a bit of a wall.
I've created A virtual directory to the apps www folder, I believe I've set permissions correctly (ive copied test asp pages into the folder and these have run fine in IIS) Asp pages are allowed to run but when I browse to the site I get...
Critical Error
The PingPlotter web interface had an error.
Couldn't create PingPlotter Object.
Make sure rights to the PingPlotter engine object are correctly configured.
Error: 006~ASP 0177~Server.CreateObject Failed~80080005
Source: Server object
And the following appears in event viewer...
Event Type: Error
Event Source: DCOM
Event Category: None
Event ID: 10010
Date: 28/04/2006
Time: 11:27:15
User: ******\IUSR_*******
Computer: *********
Description:
The server {C7CEDE66-8336-4BAE-AB5A-BFF83A1EE36E} did not register with DCOM within the required timeout.
For more information, see Help and Support Center at
http://go.microsoft.com/fwlink/events.asp.I think this is possibly a problem with the anonymous user not having permission to access something Ping plotter needs, but I have no idea what...
Any assistance greatly appreciated,
Cheers
