#1515 - 10/27/05 07:44 AM Copying setup to another computer
Jimmy E. Frederiksen Offline
Pete, if I want to copy my MultiPing setup to another computer how do I do that?
I can figure out how to save the workspace but what about alert setup and the options?
#1516 - 11/02/05 09:07 PM Re: Copying setup to another computer [Re: Jimmy E. Frederiksen]
Alerts are saved in the "Alerts.ini" file in the MultiPing install directory. All other settings are in the "MultiPing.ini" file in that same directory.
If you install, then copy those two files, along with the workspace files, then you should have a matching configuration on the destination computer.
#1517 - 11/03/05 10:31 AM Re: Copying setup to another computer [Re: Pete Ness]
Thanks, I'll try that!
