#15 - 04/30/99 10:05 AM Automatic Resume mode
molinari Offline
I have installed PingPlotter 2.03 on a unattended server monitor to check my direct internet connection with the carrier. <br>When the server monitor has an unexpected shutdown, PingPlotter automatically restart BUT in RESUME mode, and it wait for a click on RESUME button.<br><br>How can I restart automatically PingPlotter with the command RESUME automatically clicked?<br><br>Thanks in advance for your response.<br><br><br>
#16 - 05/01/99 12:30 AM Re: Automatic Resume mode [Re: molinari]
What command line are you using? Do you want to "resume" an existing trace? If this is the case, try adding /TRACE to your command line. This should start it tracing immediately into the file that you're launching.<br><br>Example:<br><br>pingplotter www.nessoft.com.pps /TRACE<br><br>This will resume tracing in the file "www.nessoft.com.pps".<br><br>Hope the helps!<br><br><br><br><br><br>
0 registered (), 29 Guests and 0 Spiders online.
