#1495 - 10/06/05 10:06 AM Alert when host is over 80ms
Jimmy E. Frederiksen Offline
Currently I have an alert that get's fired when a host is unavailable (3/4 samples are over 9999ms).
Is it possible to make an alert that fires when a host is over 80ms for 3/4 samples? I've tried but it my problem is that it also will fire when the host is unavailable.
Any workaround to this?
#1496 - 10/06/05 02:44 PM Re: Alert when host is over 80ms [Re: Jimmy E. Frederiksen]
Hi, Jimmy.
There's no way to set up an alert that *only* fires if the latency is slow, but not when it goes completely down. How are you wanting to use this?
#1497 - 10/07/05 04:34 AM Re: Alert when host is over 80ms [Re: Pete Ness]
In general we say that our hosts shouldn't be over 80ms. If it's over something might be wrong.
Techincally I don't know how you could solve this but perhaps you could make an alert that fires when a host is over 80 ms and but still under 1500ms?
#1498 - 10/07/05 09:07 AM Re: Alert when host is over 80ms [Re: Jimmy E. Frederiksen]
Hi, Jimmy.
I guess I should have been a bit more clear in my question.
What's the downside of being alerted if the target stops responding, too? That will certainly be a bad thing - at least as bad as if it's slow...
#1499 - 10/27/05 04:21 AM Re: Alert when host is over 80ms [Re: Pete Ness]
Well now that you're asking I don't know why really. <img src="/forums/images/graemlins/crazy.gif" alt="" />
I guess it just would be nice to see whether the connection is slow or down when I get the notification in the system tray.
I could change the current alert I have when 3/4 samples are over 9999ms to 80ms. But then I would also change my notification text to something like "site x is down or slow".
This way I have to open MultiPing to see whether I should react now or perhaps wait a bit if it's a slow connection.
So if I could have 2 alerts I didn't have to open MultiPing to see what the problem is.
0 registered (), 264 Guests and 0 Spiders online.
