#1119 04/02/04 09:45 PM
Anyone have any Idea why the Route Changes Box is not showing up. I just Downloaded the eval of 2.50
#1120 04/03/04 02:30 AM
The routes area only appears, by default, when there is a route change. I suspect that you have route changes, though, or you wouldn't be asking this, right?
There are a couple of things you can look at.
1) There is a heavy line right above the "sampling" word, that is a splitter that you can drag to open the route change window. It's at the very bottom of the Address history box, and above the "Sampling" word. The mouse will change when you have the mouse in the right place. Just drag it open.
2) In the "Route Changes" tab in the Advanced Options dialog, there is an option for "Show route change indicator when list hidden". When this is turned on, and the route window is hidden, a message will show when the route changes to indicate that it has. Double-clicking on this message will show the route area.
Let us know if this doesn't get things working the way you expect and we'll do our best to help.
