For fine tuning purposes.. I need to have an integer incremented Trace Interval. <br>That means instead of the 1, 2.5, 10,.. etc fixed values.. I need a parameter <br>which can be set at any number starting at 1 and going to.. say 60 or 90.<br><br>gabbey<br><br><br><br>
You can type in anything you want into the trace interval. For example, you can enter: ".5 seconds", or "4 minutes" and it will accept these vales. The listed values are just so the average user doesn't have to type in the interval. These are guidelines - not limits.<br><br>
