#331 11/21/00 03:37 AM
I am using 2.20 and was watching my MAX times so I could report them to my ISP. While watching the MAX time I saw that the MAX time will go up and down for a node. One minute it is 500+ next it is 200+ even though the route did not change and the latest measurement was no where near 200 or 500. Any ideas?<br><br><br>
#332 11/21/00 06:49 AM
The Min, Max and average values displayed in the upper graph are all based on the "Samples to Include" setting. If you have this set to 10, then these numbers only come from the last 10 selected samples. Changing this to 0 will show ALL samples.<br><br>I suspect that you have a "Samples to include" number set, and that the maximum values are "scrolling" off the old end of this sample set as new values are included/collected.<br><br><br>
Pete Ness #333 11/23/00 05:14 AM
That was it thanks!<br><br>
0 members (), 40 guests, and 2 robots.
