If I ping to a host 15 - 18 hops away.. and enable several Timeline <br>graphs.. then drag them up vertically for better display.. the graph <br>timeline scrollbar doesn't come on till I adjust one of the column <br>widths.<br><br>It should come on as soon as the Timelines infringe on it 'territory'.<br><br>gabbey<br><br><br><br>
Yes - this is a known defect with the control I'm using in the upper graph area. As you noticed, all you have to do is resize the window vertically at all and the scroll bar will come on.<br><br>I have this on the defect list, but I'm not sure exactly when this will make it in - since the fix isn't immediately obvious.<br><br>Thanks for the info!<br><br>
0 members (), 22 guests, and 1 robot.
