#2375 09/04/12 06:12 PM
I can't seem to get the data to save on startup/reload on startup to work.
I have Windows Service and Starup settings: workspace to load defined as c:\temp\NHCPingplotter.pws. Automatically update workspace on shutdown reboot, checked. Save collected Data on shutdown/reload on startup, checked. Save file location defined as c:\temp\nhcpingplotter
I also have default settings, Autosave checked with a save interval at 30 minutes. Default Filename = $dest $date $hour00
I can see that the workspace c:\temp\NHCPingplotter.pws doesn't appear to be loading at startup. Is there something I am missing or a setting I haven't set correctly?
Did you find an answer to this? I too am interested in having historical data reload on startup (the next morning, in my case)
BWB8771 #2412 06/06/13 02:39 AM
Sorry, we took the answer to this offline via support.
In PingPlotter Pro, the workspace can auto-save and auto-reload on close / restart. This should do what you're after (I think).
We cover the workspace here:
http://www.pingplotter.com/manual/pro/workspaces.html
And we cover the idea of auto-reloading here:
http://www.pingplotter.com/manual/pro/automatically_start_tracing_wh.html
If that doesn't work for you, let us know. smile
0 members (), 22 guests, and 0 robots.
