#2044 09/15/08 10:28 PM
Greetings!
I have 2 NICS on 2 different subnets (10.0.1.X, 10.0.3.X) connected to two different WAN interfaces. I would like to be able to monitor traffic to a single remote destination through both ISPs. Is there any way I can do this?
Thanks!
R3PIOV #2045 09/15/08 11:48 PM
PingPlotter Pro can handle this. You can set up multiple configurations, and have one configuration use one adapter, the other configuration use the other (and a third, possibly, let the operating system decide which to use).
We cover this topic here:
http://www.nessoft.com/kb/61
Just set up two configurations, one for each interface (make sure you properly name the configurations so you can tell the difference).
If you're planning to set up alerts, you'll want to use the latest beta for PingPlotter Pro, since it lets you set up target or engine-specific alerts, while previous versions only let you alert based on an IP (and in your case, the same IP might be participating in both routers).
If that leaves you with questions, please let us know.
0 members (), 32 guests, and 1 robot.
