Can Ping Plotter cloud integrate with SD-WAN SLA metrics to reveal the underlay ISP infrastructure route? Basically it needs to be integrated with Cisco thousand eyes. For companies like Amazon anything less is not good enough. I realize this forum seems to be focused on the standard and pro editions. I don't see one for the cloud edition.
TJM
Hi Jibroni,
Right now, PingPlotter Cloud doesn’t integrate directly with SD‑WAN controller SLA metrics (for example, it can’t automatically pull in or overlay the provider’s own SLA stats or internal underlay topology). Instead, Cloud measures performance by sending its own probes (ICMP/TCP/UDP) from an Agent to collect Ping/Traceroute data and reveal the network route to your selected target.
If you want to dig deeper into the details for your specific use case I suggest that you send us an email (support@pingman.com), this way we can also loop in anyone else that may need to be involved along with getting a feature request created on your behalf (if we don't have what you need currently).
