#3971 - 09/27/22 07:32 AM Packet Loss Help
Austinite Offline
Have spectrum and have had intermittent packet loss. They have replaced the line to the main cable node in the neighborhood without any help. I am having a hard time reading which hop is causing the packet loss.
To the router: https://share.pingplotter.com/GQxdePQavC2
To Google: https://share.pingplotter.com/bJchpDaJ7sd
To Cloudflare: https://share.pingplotter.com/NdyAc6u3u8W
Can anyone help me decode this?
Thanks
#3973 - 09/28/22 07:12 PM Re: Packet Loss Help [Re: Austinite]
Hey Austinite,
Based on these share pages, it looks to me that there may be some issues coming from your router/local network which is where I would suggest starting your troubleshooting efforts. If you look at your trace directly to your router, it looks like there is a latency spike of 100+ms every half hour.
In first troubleshooting your local network I suggest checking out the following article:
https://www.pingplotter.com/fix-your-network/local-network-problems.html
After troubleshooting this latency in your trace to the router, if issues still exist to external targets such as Google or Cloudflare DNS, I suggest then capturing data representing these issues and sharing them with your ISP. You can read more about this and building a case with your ISP in the following article:
With that said if you have any other questions about your results or if there is anything else I can help with please let me know!
0 registered (), 20 Guests and 0 Spiders online.
