Hey Austinite,
Based on these share pages, it looks to me that there may be some issues coming from your router/local network which is where I would suggest starting your troubleshooting efforts. If you look at your trace directly to your router, it looks like there is a latency spike of 100+ms every half hour.
In first troubleshooting your local network I suggest checking out the following article:
https://www.pingplotter.com/fix-your-network/local-network-problems.html After troubleshooting this latency in your trace to the router, if issues still exist to external targets such as Google or Cloudflare DNS, I suggest then capturing data representing these issues and sharing them with your ISP. You can read more about this and building a case with your ISP in the following article:
https://www.pingplotter.com/fix-your-network/build-a-case.html With that said if you have any other questions about your results or if there is anything else I can help with please let me know!
