#3813 01/17/21 10:06 AM
https://share.pingplotter.com/gtSUjnqmuiN.png
As you can see i have a lot of packetlost.
Also the ping is quite unstable.
I share my router with two other households. 6 people are using that connection.
I think it looks like im using to much bandwith.
But its a 100Mbit connection and im pretty certain everybody was asleep when i made the test.
TJM
Hi Kreu,
I took a look at the PingPlotter data you provided and it appears that this issue may be originating around hop #2. To help zero in on this issue I suggest running a trace directly to hop #1 (your router) to rule out any ICMP down-prioritization that is happening in your trace.
You can learn more about ICMP down-prioritization in the following article:
One poorly responding router
After running traces to your router and Google simultaneously you should be able to identify if this is a hop 1 or 2 issue easier.
You can learn more about interpreting PingPlotter results in the following articles:
Interpret Results
Common Network Problems
If the root of this issue does end up being outside of your home network (not the router) you may have to reach out to your ISP, if that is the case I suggest reading the following article:
Building a Case
0 members (), 27 guests, and 1 robot.
