#3467 - 09/15/19 06:48 AM music alarm problem
kobi Offline
HELLO
im using with pingplotter
I config when the ping for 8.8.8.8 is loss the music alaram is on
But I when the ping is come back the sound is still countine playing
can someone help me plz?
tanks
#3469 - 09/16/19 12:49 PM Re: music alarm problem [Re: kobi]
Hi Kobi,
We have a wealth of knowledge regarding alerts online - check out some of these resources if you haven't already:
https://www.pingplotter.com/manual/help_alerts.html
https://www.pingplotter.com/manual/troubleshooting_alerts.html
If those don't help - would you mind sending me a support ticket from inside the program? You can do so via Help -> Email PingPlotter Support. This should give me what I need to look at your setup - but I'll let you know if it doesn't.
#3472 - 09/18/19 02:35 AM Re: music alarm problem [Re: Poe]
kobi Offline
hello tanks is that free trial alram music in included in the free version?
#3477 - 09/20/19 03:49 PM Re: music alarm problem [Re: kobi]
Hey Kobi,
In the Free version, we don't have the ability built in to send alerts of any kind - so the music that we include won't be usable as it is in the Pro trial that you're likely running right now.
If you're interested in alerts, we do have a pretty affordable option for PingPlotter Standard (which is a bit more limited than the Pro trial but should allow you to send some alerts). You can grab a monthly subscription for Standard for $6.99 monthly here if you're interested:
https://www.pingplotter.com/products/purchase
Let me know if you have any other questions!
