#3316 - 10/30/18 04:14 PM Modem, Router, or ISP problem?
dehb Offline
Hi all, I would really appreciate some help interpreting my results: https://imgur.com/a/49iTVHW
I've had weird wifi connectivity issues for a while now. For the most part, the 5ghz band on my router works fine with some occasional outages, but the 2.4ghz band very often refuses new connections and has intermittent periods of 100% packet loss. These outages mostly affect wifi, and I rarely if ever lose connection on my desktop computer which is plugged into the router by ethernet. Anecdotally, my family says the issues occur mostly when everyone is all home at once (i.e. many devices are simultaneously connected) but I'm not sure how true this is.
I replaced the router with an identical one which I had lying around the house, thinking it must be failing, but that didn't fix the problem at all. I've also tried factory settings on the router, updating firmware to the latest, changing a million different router settings, and finally I also replaced the modem with a brand new one, but I'm still having issues. The ISP tech also didn't really have any suggestions.
Also attached are two ping plots from the same time of both ethernet and wifi. Hopefully I've provided enough info, but I can provide more on request.
Thanks in advance for the help.
Wifi (2ghz).pp2 (1035 downloads)
Ethernet.pp2 (894 downloads)
#3317 - 10/30/18 04:26 PM Re: Modem, Router, or ISP problem? [Re: dehb]
Hey there!
Thanks for getting in touch.
We have a pretty handy guide that should help you through that process, and that's located here:
https://www.pingplotter.com/fix-your-network/getting-started
That being said, I do see in your screenshots quite a lot of packet loss - but I'm not quite seeing that in the .pp2 files you sent over. Let's address the screenshots using the guide above, and the following page that outlines some common network problems:
https://www.pingplotter.com/wisdom/common-network-problems/
It does look like you have a lot of packet loss starting at hop 1 and propagating through, so this is really reminiscent of the "Bad Hardware", "Bandwidth Saturation", or "Wireless Interference" cases we've outlined in the latter article.
I hope that helped you out in your troubleshooting journey!
