#2592 12/25/14 11:11 PM
hello,i have some weird lagg spikes when im playing,not sure against what im fightning there but this first bump have constant latency drop and rise,what is that
Hop 1, by itself, has a classic bandwidth saturation pattern (http://www.pingplotter.com/commonnetworkproblems/#sawtoothsat), *but* hop 3 looks good, and the final destination looks fantastic. This means that your DSL modem at hop 1 isn't prioritizing the creation of ICMP TTL expired packets. This is actually pretty common, and doesn't imply there's any problem.
What you're looking for is a problem at the final destination, then you can look upstream at earlier hops to see where that problem originates. Since you're using PingPlotter, I suspect there is probably some World of Tanks problem you're troubleshooting.
Trace with PingPlotter while you're gaming. If you experience a problem that you think is network related, look at PingPlotter's final destination for latency and/or packet loss. If you see that there, then try and correlate that latency / packet loss with the problem you're seeing in-game. Then, look at earlier hops to see which hop that pattern starts at. That's the culprit.
If you don't find a pattern in PingPlotter while gaming, then your problems may not be network related.
We talk about this technique in depth here:
http://pingplotter.com/netnirvana/
Best wishes (and happy holidays!).
0 members (), 49 guests, and 2 robots.
