#2252 - 01/31/11 12:51 AM Severe packet loss issues, what do I tell my ISP?
BrunDeaG Offline
I keep telling my ISP I have packet loss issues, but they keep telling me my line is fine. What should I tell them, or ask them to do to fix the issue? What's wrong with my line (which seems to be the problem)?
http://img821.imageshack.us/img821/4797/wwwgooglecoma.png
#2253 - 01/31/11 12:56 AM Re: Severe packet loss issues, what do I tell my ISP? [Re: BrunDeaG]
Actually, it looks like your hop 1 packet loss is just as bad as it is downstream - and hop 1 is inside your own network. Based on this, I'd say the problem is with your own network, *not* your ISP.
If you're using wireless, then that could have issues and be causing packet loss. If it's wired, then look for a bad router / hub / network cable.
The latency at hop 1 is 0ms, which usually means it's in your network, not the ISPs.
0 registered (), 76 Guests and 0 Spiders online.
