#147 05/05/00 04:52 PM
I would like to know if an offline viewer could be made available to expand on a section of saved info.<br><br>Or a scrolling window based on time line?<br><br>Also a feature to automatically save data on a predefined period. I.E. Save data daily to a file.<br><br><br>
#148 05/12/00 02:03 PM
The auto-save feature is implemented in version 2.20. There is no separate offline analyzer - you can use an instance of Ping Plotter to load this data and change the parameters to show just the data you want..<br><br>
