Extension Goal:
Sometimes, during a collection period, you might change the "engine" you're using to collect data, or maybe the packet size. This extension will create a comment in your collected data when you make one of these changes:
  • Change of the packet size
  • Switching the named configuration
If the change makes a difference in latency or packet loss, you can see that a change was made by looking at the time graph.
This extension requires PingPlotter Pro 3.00.3p beta 9 or higher. It will *not* work on the released 3.00.2p version.
Installation Instructions
  • Download the attachment from this post (link near the title). The file will be named "Log Engine Changes.ppx".
Now, whenever you make one of the listed changes, look at the time graph for a comment to see the change.
Wrap up
There are other setting changes that could be logged. Post here for your needs and we'll see what we can do to help with this.
Log Engine Changes.ppx (833 downloads)
