#3042 - 04/04/17 03:08 PM Only first hop is 40-50%?
vilivilperi Offline
So i kept my pingplotter on about 10minutes and result is that first hop is having 40-50% packet loss. 2nd row is empty (still saying 100% packet loss thou) and all others had 2-4%. Does that mean that problem is at my side or at internet provider side ? I can link image if needed, and sorry for being beginner in computers smile
Edit: I have been testing this with 2 different routers and 2 different pc. Both pc's got 40-50% packet loss...
Edit2: Here is picture what it looks a like.
https://imgur.com/a/GEqKE
Edited by vilivilperi (04/04/17 03:22 PM)
#3043 - 04/04/17 04:34 PM Re: Only first hop is 40-50%? [Re: vilivilperi]
Kody Offline
Hi there,
I've taken a look at the screenshot you linked and I'd be happy to provide some guidance here.
Even though hop 1 (your router) is showing significant packet loss, the packet loss does not carry through to the rest of the hops and is not consistent all the way through, therefore this is not indicative of an issue with your connection. Here's a knowledge base article from our site that talks a little bit about this:
https://www.pingman.com/kb/6
Based on the screenshot as a whole, I don't see anything that stands out as a "problem" within your connection. Your final destination is reporting ~1% packet loss which should be low enough that you don't notice it during normal use.
Cheers,
Kody
#3044 - 04/04/17 04:55 PM Re: Only first hop is 40-50%? [Re: Kody]
vilivilperi Offline
Thanks for fast reply, but i see so much "lag" in my internet. Thats why i originally loaded this program. In example when using Teamspeak sometimes my voice goes so blurry and same time games starts lag. This is only like 10s-30s but happens a lot. Also when watching some streams and it has automatic resolution (goes fullhd with good connection and 360p with bad), it goes from fullhd to 360p many times... (Sorry for bad english). Im confused cuz this "lag" happens with 2 pc's and with both routers..
#3045 - 04/05/17 11:01 AM Re: Only first hop is 40-50%? [Re: vilivilperi]
vilivilperi Offline
Okay, i think i found the source of lag now laugh
http://imgur.com/a/KJqwF
Got this one today. I was just playing casually and noticed i started lag like always, then put pingplotter on and got this result in 5minutes. I think this is bad and not in my end ?
